Ford 960 wide adjustable front end parts help
Acrow
New User
I am trying to figure out where to find the parts for this front end. The service book says it shares many parts with the standard front end but the center axle pin is different. I am looking mainly for the bushing but may need the pin as well. The whole front end tries to roll forward and backwards. Thanks for the help.
If it has the HD axle and it probably
does you aren't going to be happy.
Messics has both. Just go to their
website and put your model number in.
The pin can be found on eBay or pert
near anywhere else. The bushing isn't
available anywhere but NH. $50 will get
you a pin. $300+ for the bushing. It is
a thin hardened steel bushing.
If yours still has a bushing reuse it.
Put in a new pin. The axle housing is
most likely egged out. Clean it good
with brake cleaner, rough it up with a
rat tail file and jb weld the bushing in
place. Let it cure 24 hours before
putting it back together.
(quoted from post at 10:21:12 10/07/21) I would post a photo but it keeps saying its against community standards
Acrow, once you have posted 5-6 times you will be ale to post pictures. Or you can just go down to the site comments forum and ask the moderators for permission.
