Ford 641 draft control plunger
Tim61
New User
I have a Ford 641 that the 3 point lift would hardly lift. I removed the lift cover. The draft control rod was slightly bent and was welded aprox 2 in from the threaded end. The threads on this rod are coarse and the new 8N-541-B has fine threads. The yoke on the tractor is a NCA-546-A. This yoke is 6 1/2 inches long. Looks like the 9N-546-C is 4 inches. If I put one of these on. Will my length be too short at the rocker? Any help would be greatly appreciated.
The plunger is the same and is fine thread and so is yoke. NCA-540-A is part that gets bent, dogleg looking part. The cam follower pin causes most of the not lifting hi enough.
That part is fine. The cam follower pin was worn and is being replaced. The threads on the old draft control rod and the yoke are coarse thread. The new draft control rod has fine threads.
