Tractor left brake can be mashed almost to the floor, so we removed the wheel, the brake cam shaft, and removed the hub. Everything inside looks good and attached correctly.
However, with the hub off we reconnected the cam shaft so we could watch the action of the square end of the cam pivot and spread the brake pads. As the cam turned the bottom brake assembly moved well but the top assembly did not AND the brake pedal would not spring back to its raised position. We put a screwdriver in the assembly and the top assembly was moving like the bottom assembly. The cam shaft had a plus or minus 1/8" up and down movement.
So the top assembly doesn't rotate up, the brake pedal does not spring back up and the and the cam shaft has play in it at the wheel in.
As you can see from the picture, the end of the cam shaft square end fits very well and snugly in between the assemblies.
Can someone point us in the right direction? Thanks. (sorry, duplicated one picture and could not remove it.
