hotrodjeremy
New User
I am hoping someone can help me, I am at my wits end. I got a pin hole in my hydraulic pressure line. I bought a new line (Part # D0NNH867D) When I received it I found that it didn't have the fittings on either end. I ordered 2 (FDS3714) fittings from yesterdays tractor. I put the fittings on the line and put the tractor all back together. The connection going into the sump has held fine with no issue, but the end going into the pump blew the line right out of the fitting. So I found a video on YouTube explaining that these cheap fittings that don't have the steel washer tend to not seal or leak so I bought 2 GR2117 because it was the only set I could find that had the steel washer. I put it all back together and this time it held for about 3 minutes before blowing the line right out of the fitting again. So fearing that I didn't get it back together just right I tried again. I put it all back together using a new fitting and made sure it was tight as I could humanly get it. It held for about 5 minutes and again blew the line right out of the fitting. I cannot get any fittings to hold the darn line in the fitting once the pressure has built up in the line. Please someone tell me there is a line assembly that has the end already on it or something that can hold my line in the fitting. PLEASE FOR MY SANITY! SOMEBODY HELP ME!
