Ford 841 Diesel Manifold Bolts
buick8
Can anyone describe the exhaust and intake manifold fasteners?
Bolts or studs, or combination? Size?
I have what you might call a kit (a lot of assembly required) and cant
find another tractor to look at as a go-by.
I have 4 diesels, all are random, closet I think is front 2 bolts,front upper intake 2 studs, lower 2 bolts next each other, upper ex stud, lower ex bolt.
The 1953-'64 Parts Manual lists for all 4 cylinder diesels, 1958-'64 :
3) #20450-S8 -- Bolt, 7/16-14 x 1.38 hex head
2) #304832-S8 -- Bolt, 7/16-14 x 2.00 hex head
3) #88413-S8 -- Stud, 7/16-14+20 x 1.75
Like Shaun says, after 60 years of being removed, mixed up, broken, lost and replaced, I dont think Ive ever seen them used the same sequence on any two otherwise identical tractors!
