towing sos ford
I am acquiring an sos tractor that is not runnable at this time and I remember there is a way to tow it when not running. I owned such 50
years ago, but never had this issue. I seem to remember there is a disconnect somewhere that releases it for towing. I do remember the
transmission locks when the engine shuts off. Don't ask how I know.Can anyone shed some light on this ? Thanks for any and all help
There is a traction disconnect.
Where it is and how to use it depends upon year and model.
Dean
As stated, there is a traction disconnect. Look for a two-position lever on the rear axle about inline with the forward end of the pinion shaft.
Yes. Model # would be helpful. Typically on the left side of center housing on pre-'65 models, and on the right on '65 and later models.
on my 4000 4cyl. it uses a 11/16 wrench to remove the nut. Then flip the lock over. I keep an old one in the tool box just in case it ever dies out in the field. Al
(quoted from post at 08:54:49 09/25/21) on my 4000 4cyl. it uses a 11/16 wrench to remove the nut. Then flip the lock over. I keep an old one in the tool box just in case it ever dies out in the field. Al
Not sure what an old one does if it dies . . . unless you're afraid of losing one??? Just remove nut and keeper strap and flip the eccentric clockwise (rocking rear wheel or a 12 " adjustable end wrench will help in the process).
(quoted from post at 09:49:21 09/27/21)
Ha! Ha! Bern. I challenge you to find parts claiming to be for a '58 671!
True, but serial numbers and date codes on the transmission casings themselves show that some were made in late '58.
(quoted from post at 09:59:08 09/27/21)
Doesn't say they weren't called '59 models. CNH parts shows SOS parts beginning 1 of 59.
