6610 dual power
thumpa
New User
Morning all,
trying to work out how to get to the dual power solenoid on my 6610 series 2, have
traced the yellow wire which goes into the bell housing under the brake controls, which has 12v power, do you need to lift cab?
Looks for the big rubber boot on the RH side of the transmission case with two oil lines going into it, likely behind the cab mounting
bracket. Peel the boot back and wa-la, there it is.
