tripper225
I got a engine overhaul kit from yesterdays tractor. The crank main bearings for .01 under are not the same size. The front and rear bearings are .002 larger than the crank installed in the block. The center main is .003 larger than the crank installed in the block.
The manual calls for .0007 to .0023 oil clearance for all three mains.
Two questions.
Is it correct to have more clearance in the center main to lubricate the thrust surfaces?
Is it correct to have the clearances toward the high side of the factory spec?
Thanks in advance for your assistance in this project.
Jim
Two questions.
Jim
