New Holland 2910 light switch knob
okgat
Good day,
I have looked at my light switch knob and I find no way off removing the light switch knob. Are these pressed on?
How do you remove it without breaking the knob?
Thanks,
Rick
I have a couple of other questions if you don't mind.
1. How do you remove the knob on the pull out cut off switch?
2. Is there a fuse box on this model? If so, where is it located?
I checked and found the voltage regulator and the only literature I have read said a fuse box was next to the regulator, which is behind the battery tray. But, I was not able to locate it.
Thanks again,
Rick.
Diesel? Knob doent come off. Has nut on backside, cable comes out thru hole. Only fuse is behind inst cluster for fuel/temp gauge.
(quoted from post at 15:59:21 09/18/21) Diesel? Knob doent come off. Has nut on backside, cable comes out thru hole. Only fuse is behind inst cluster for fuel/temp gauge.
Thanks again, you were very helpful.
