What size tire for the front of a 4000 3cyl
root
Right now my 68 4000 has 7.50-16 on the front and seems to st way too high. Is the original tire a 6.00-16 for this tractor.
6.00x16 was standard, but there were
options, including 7.50x16 (my son's '65
4000 has them, and 13.6x38 rears) and
7.50x18.
What size rears does yours have? Short
rears will affect the stance as much as
tall fronts.
(quoted from post at 11:49:49 09/17/21) 6.00x16 was standard, but there were
7.50x18.
tall fronts.
I have 16.9-30s on the rear now and it sits high in the front.
One thing I've noticed with tires for either the front, or rear is that the height of the tires vary quite a bit depending on who made them. I've seen 13.6x28's that varied almost 4" in height depending on who made them.
4000 sets high in the front
Dropping down to a 6.00-16 will lower the front 2 inches but the tires are narrow and require a narrower rim
A better option is the 7.5L-15 that is same height as a 6.00 but is as wide as a 7.50
When Ford introduced the 4600 that replaced the 4000 the only front tire they offered was the 7.50-16
This post was edited by Destroked 450 on 09/18/2021 at 08:47 am.
(quoted from post at 08:45:29 09/18/21) 4000 sets high in the front
Can you recommend a good place to get the 15 rim. I need to buy new rims anyway. One is 3.5 bs and its way to close to the knee
