Ford 2000 two shift levers??
When did Ford on the 2000 series tractor switch from one shift lever to two??
Am I correct in thinking that the shift pattern with two levers is similar to the MF 1,2,3 and H,S,L shift pattern. ??
Thanks, Jim
65/later 3 cylinder 2000s could have a single shifter 4 spd trans, a 2 shifter 6 spd with 3 forward and 1 reverse gear in high or low range, plus a 2 shifter 8 spd trans with 4 forward and 1 reverse gear in high or low range
