I am trying to troubleshoot an intermittent transmission issue with my Ford New Holland 675d backhoe. It is a 4x4 unit. The backhoe engine runs well.... A few weeks ago, the transmission started to intermittently slip and or is failing to engage in reverse and sometimes in forward. Sometimes it doesn't do either, but I noticed it first in reverse backing up a hill. I have noticed the condition occurs when the tractor is both warm and cold conditions on level and angled surfaces. I have changed the transmission filter, checked the fluid (might be overfilled), I checked all the wiring. I checked for leaks in the transmission cooler, I metered the transmission control unit under the dash and that appears to be working or meets voltage requirement when placing it in and out of gear. I have been running it with a gauge on it and it doesn't appear to be anything abnormal with the transmission pressure. Does anyone have any ideas or have any more trouble shooting steps? I have patiently been going through the book and trying to trouble shoot the issue. Sometimes when driving the tractor forward or reverse it just fails to move. I have also noticed the issue when transitioning from forward to reverse? All I know is that it is not consistent.
Shuttle valve issue?
Switch issue?
Bypass issue?
Clog?
I created a video so you can see the issue. The transmission is slipping in reverse in the beginning of the video. The transmission reads at 150 psi at engine idle and it rises up to approximately 180 psi during rolling operation.
Thanks in advance for the comments or help.
I haven't tried to verify if the issue exists when the tractor is run in 4wd. I will try to verify that in the coming days.
Youtube video: https://youtu.be/wAYjFlWj70I
This post was edited by RandyFord on 09/15/2021 at 03:10 pm.
Switch issue?
Bypass issue?
Clog?
