Company Logo (800) 853-2651 Shop Now
Re: NH Hydraulic Transmission Oil Premium = 134d?
RustyShackleford
09-14-2021 20:39:54
Thank you all for your replies. Just a followup, I noticed on the new version of Traveller oil, 2 gallon item T806383, it actually lists the original M4864A Ford rating on the label (and also 134D). It also says SAE 10W-30, but I think that is crankcase oil rating which would be comparable to SAE 80 gear oil in actual viscosity?
RandyFord
09-15-2021 19:29:10
 Re: NH Hydraulic Transmission Oil Premium = 134d? in reply to Bern, 09-14-2021 20:39:54
Is this the NH transmission fluid you are referencing?
Multi-G 134
https://www.messicks.com/part/9624656ds/1-gal-134-hydraulic-transmission-oil
This post was edited by RandyFord on 09/15/2021 at 07:29 pm.
Matt in Oz
09-15-2021 04:53:51
 Re: NH Hydraulic Transmission Oil Premium = 134d? in reply to RustyShackleford, 09-14-2021 20:39:54
Hey Rusty isn't oil viscosity standard just like temperature or air pressure. It is a standard measurement. This gives different oils for different applications. Googgle viscosity.
Today's Featured Article - It Can't Be Done! - A Tractor Story - by Neil Campbell. I'll never forget the time back when I was a boy baling hay on our Farm in Big Rapid, Michigan. The most memorable event that took place was a trip up the steepest incline on the farm pulling an old New-Idea baler with a pony-motor for power and a haywagon. I had just talked my Dad into buying an old John Deere B with 6-speeds ahead and I was real proud of it, except it was a little smaller than the Case tractor that we normally ... [Read Article]
Latest Ad: 1959 Case 210B has a loader, hydraulics hoses are 3 years old,have a back blade, duals, brush hog and finish mower for it. Runs good but has a little hydraulic leak - not bad enough to make me want to tear it apart. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
