New member here, I have found a lot of great info on these forums and would like to thank all of the contributors. Hopefully I can also help someone in the future.
I have a "new to me" 550 backhoe with the 6x4 manual reversing transmission. Trans works well with no odd noises or anything that seems unusual except that it will pop out of gear under load. This is only the main selector and gears, the high/low selector functions fine. Some gears maybe more than others, especially the forward gears. But it is load dependent and I usually am not putting much load on the reverse gears.
The work-around for now is to either hold it in gear with hand or a bungee. Doing so I am able to work OK but obviously it would be easier to use if I could repair it to work correctly.
I found a number of posts suggesting the detent balls/springs may cause this. I replaced all of them with new parts and now have nice positive clicks when shifting in and out of each gear. However it will still pop out of gear under load.
I have changed the fluid and did not see any metal debris. Of course it could have been there and come out years ago when someone else changed fluid.
I have not found a lot of information on what to look for next. I am specifically looking for any possible next steps before completely tearing the transmission apart.
The shift forks are accessible via the top cover and they appear fine to me, not bent or loose. I can move them through the various gears with a pry bar and the motion is looks and feels OK. Could they be mis-adjusted? I have a copy of the service manual but am not finding specific info on how to adjust the forks before locking them down.
What is meant to actually hold the transmission in a selected gear? I am not familiar with tractor transmissions but am with automotive. Looking at the parts diagrams it really looks like a bunch of straight cut gears with no method of locking in gear other than the detents I have already replaced.
Are there dogs that may be worn? Are the gears very slightly beveled so that they should lock in place under load? Something else? Is there a way to check for wear without disassembly?
