mjsnodgrass
i have a diesel 3600. this weekend i was using the tractor with a big disc. position / draft controls worked as they should. tonight, leaving
the field i used the position control to lift/transport the disc. the position control lifted the disc very slow, like it was low on oil. the
draft side of the system lifts the disc like it should. i changed the hydraulic filter. it didn't make a difference. the tractor has plenty
of oil. i assume the system uses the same cylinder for both draft and position. the adjustment of the flow control doesn't seem to make a
difference in speed for position control. the position control lever doesn't feel as crisp in it's movement as it did this morning. anyone
have a idea why draft would work and position won't? thanks for the help
