(quoted from post at 19:14:09 09/09/21)
aj, you need a few posts in order to be allowed to post pictures, or you can just go down to the site comments forum and see if you can convince them that you are not a "bot" and get permission.
(quoted from post at 19:00:04 09/09/21) Well...too late for that advice haha. I guess I'll see how it runs tomorrow. Prior to seeing this, I cranked that all the way out and moved the nut around..I put it back as close as I remembered to where it was when I took it out...hopefully I didn't jack it up.
(quoted from post at 10:40:18 09/10/21) Update: I took the tractor out for a spin today and here is what I noticed.
-Not much change happening between 1-4 although I can feel the slight jolt of the gear shifting like normal, which is how it was before. A big jump into 5 (same as before) , steady increase into 6.
6 to 7 slows down...which it did before but that made no sense.
7-8 very subtle change if anything. Big jump into 9.
9 to 10. I honestly can't tell if it's going into 10 but something isn't right there. The shifter handle doesn't click, I don't feel much of a jolt or gear grab. Tractor doesn't change speed. I counted back to one and climbed back up to 9 counting each shift to make sure it wasn't just the pointer arrow being off center. Truth be told I don't know if I ever had 10 because I don't remember having to really fast gears at the end. Maybe skipping 9...I don't know. That's my update.
(quoted from post at 21:38:54 09/09/21) Pardon the pun, but I think you're screwed.
(quoted from post at 12:40:18 09/10/21) Update:
(quoted from post at 10:57:07 09/11/21) I think it's obvious that he has band adjustment issues, given the fact that he has been indiscriminately messing with them.
(quoted from post at 12:48:24 09/11/21) For the record...it was an accident...and it was only once!
(quoted from post at 16:50:04 09/11/21) I touched neither of
the other 2.
(quoted from post at 19:02:31 09/11/21)
