RedBarnFarm
Hoping to get some guidance on a Ford 420 with a torque convertor transmission. When you first start running the tractor everything seems to work fine, shift to forward, neutral and reverse with the selector fine and everything works as it should.
When the engine heats up forward and neutral are fine but when you move the selector to reverse it just sits there. If you rev up the engine after about 20 seconds or so it will suddenly jump in to reverse and go.
I took it to a mechanic (who had it for 6 months) and he split the tractor and went through some internal seals and the transmission and put it back together and said it was fixed. I picked the tractor up and ran it for 5 hours moving hay and then it went right back to doing what I described. I took it back to the mechanic (he kept it for 3 months without working on it) so I just went back and picked it up and I am determined to just fix it myself.
So - my thought is the hydraulic valve that the forward neutral reverse shifter operates is the problem. Does anyone have any experience with this repair? Totally flying blind but looks like you have to remove the diesel tank, steering column etc to access the plate where that valve is. Thoughts on if I am on the right track with the diagnosis or repair? Thanks in advance.
