I have a 6640 that wants to rev up when going down hill. If I have the throttle set a 1600 rpm and if I don't throttle it back down it will rev up to 2200-2300 rpm or so depending on the grade. Going uphill the governor works like it should and maintains engine speed.
Could this be a governor issue and needs pump work or anything outside the pump that could be adjusted to help with this?
My 4610 and 4020 do just fine on these same hills.
