We have a 72 3000 diesel made in Antwerp.
We have redone the lift cover, changed the
filters, and replaced the lines. It holds
solid in any position and doesn't bleed
off. The problem is that the engine hated
to be revved to 1500 ram or so for the
arms to lift. Once lifted all is good.
I did not change the valve on the bottom
of the tractor that looks like a bolt and
is called a bunch of different names.
Could this valve be why I have to rev the
tractor for it to lift? I am pretty much
out of stuff to change. The system was
also bled.
Thanks
also bled.
Thanks
