I bought a couple different RTV / Permatex products, but I want to get some opinions if they can be used in all areas of the tractor rebuild.
Hi Tack Permatex - this is a brush on type sealant - do people use that for just paper gaskets or is it ok for cork too?
Ultra Grey RTV - it was advised to use this on cork, but I'm wonder if the high tack will be just fine that I mentioned above
I also need something to do the bolts that go into the inside of the threaded holes. There are front cover bolts that will enter the water jackets as well as into the trans/rear axle, like where the brace that holds the step. It looks like over the years, the threaded studs have just been replaced with bolts in places. What is the right RTV for sealing threads? I'm thinking maybe the Ultra Grey will work but I saw some other blue RTV saying it's for threaded application.
Thanks in advance, the options of RTV/sealant have gone wild. Can I use one for everything by chance?
thanks, moday
thanks, moday
