Ford 7710/ 6610 first run
mikewood869
We ended up getting it running tonight. Turns out the valve were really out of adjustment. The air leak sound is coming from the fourth injectors. The tractor has 40 psi of oil pressure when cranking and 60 (only have run the tractor for 20 seconds) and 60 psi when running (for 14 seconds).
https://www.youtube.com/watch?v=w6A-kc3TLQc
Unusual to see one run with no timing cover or damper.. be careful there. Glad to see all the hard work paying back.
