67 Ford 3000 Tach Cable and Parts Diagrams Link
morekick
Gents, I've searched the forums and I can't come up with a link to the parts diagrams. These are the ones I've used before to identify things like the friction disk, original hardware, and the like.
Would someone please re-post, or point me in the right direction? My thanks in advance.
Among others I urgently need a part and am not having any luck finding it. I'm told by a friend that it's the piece that the square end of the tach cable inserts into on the generator end. He told me it's a keyed adaptor; it fits over the tach cable and has a ridge (or key) that engages mechanically with the round cavity. The cable is just spinning in the hole without it.
Again, my thanks in advance for any and all help offered.
Normally it is a gear with a hollow shaft (Part #25):
(This URL was not allowed???? Copy + paste, please)
https://www.yesterdaystractors.com/Ford-3000_Tach-Drive-Gear_C5NF17373B.html
The shaft hole is square and receives the square end of the cable. The gear has most likely come loose from the shaft.
Here is a parts list for 3000 in pdf, good quality and with bookmarks:
https://www.dropbox.com/s/ovwprfou77uwtky/FORD_3000_parts.pdf?dl=0
Edit ***
No need to register.
You download by clicking the vertical arrow at top right.
Edit ***
No response, file removed from Dropbox.
September 2, 2021
This post was edited by Hacke on 09/02/2021 at 01:33 am.
Where are you located? I have the generator with adapter and cable that I removed from my 3000 when I
converted to alternator.
Where do you put this adapter?
Is it a different drive altogether?
(quoted from post at 04:35:50 08/24/21) Where are you located? I have the generator with adapter and cable that I removed from my 3000 when I
JWA, I'm in FL, near Cape Canaveral. What would you like for it?
