M-MAN
- Location
- Bostic, NC
I have developed an oil leak when running higher rpm's. I sprayed it down with brake cleaner and as long as it's idling it stays dry. Increase the rpm's to about 1200 and it seeps. Gets a lot worse the faster it runs. It appears to be leaking from a couple injector seals but some at the valve cover. It's leaking around the breather too. There is no diesel smell to the oil.
I think the drain holes in the head are probably getting stopped up allowing to much oil to be trapped up top. If so would this affect the injector seals or do I have multiple problems? I really dread pulling the sheet metal and tank again! Any advice would be appreciated.
