avant 1735
I am working on a jubilee. The tractor was setting for many years, I drained all fluids, did an inflame on the engine, because 3 of the plugs were oily, when ever the tractor ran. Got the tractor running properly, the 3 point was working, I had some trouble with the hydraulic lift cover leaking oil. I finally got it left cover to stop leaking, but now the 3 point will not work in position control or in draft control. The arms just barely move. I have primed the pump and still no difference. Is this due to the hydraulic pump? Where should I start to look next. Thanks
