Another ID Please
Not mine, but a guy a few hundred miles from me trying to learn more about a tractor he inherited.
Told him where to check for serial numbers. He says 3 speed....doesn't sound right.
Looks like an 801 series with that separate piece around the grill. They were only available with the 4 or 5 speed manual transmissions or the Select-O-Speed 10 speed powershift trans. If he claims it has 3 speeds then it is probably a 4 speed, which would most likely make it an 841. But it could be a 5 speed and he's just not pushing it down far enough to find the bottom two gears, or the little flip-up lockout could be preventing that, which could make it an 851 or 861. Ask him for a picture showing the shifter, as they are different between the 4 and 5 speed models.
The lack of gap between the steering wheel and dash looks like 800/801.
The grill looks like 801. Lack of power steering could be either.
I agree with the others, that tractor wouldn't have a three speed.
At least, not three forward speeds plus reverse as commonly defined.
From what little I can see of the shifter, I would guess it's an 841.
Agree with other probably an 801 '58/'62. Tell him to clean up top cover should be a 4 speed. Also model and serial number above the two hole behind the starter.
<a href=https://imgur.com/aE0v0BO>
aE0v0BOl.jpg title=source: imgur.com
</a>
<a href=https://imgur.com/gIY4Mvm>
gIY4Mvml.jpg title=source: imgur.com
</a>
Got him doing all the above, and when he gets back to the tractor he'll relay the findings to me.
As soon as model is verified he's going to get a manual for it.
Heck, he may even join us here.
Thanks to all for the great help.
