Hello,
My friend just purchased a 4400 DS, loader backhoe, with a hard to read serial number. It doesn't currently run, but supposedly runs on ether, when it has a full battery to start it with.
Also the PO knows is that there is something disconnected to the fuel system. I've never seen a Ford tractor up close before to know what should be there or isn't. I'm assuming that there is a fuel shut off somewhere on the tractor, being that is it a diesel (4 cylinder).
I won't see it again until the weekend, but I'm just looking up information to prepare, so I can get it moved.
What I've noticed so far is it looks like the key switch has been replaced with a toggle switch. If that is flipped on, there is a read light on the dash board. This switch was left on for 2 weeks, hence a very dead battery, that I'm charging up now.
I'm trying to figure out where the starter button is, which the PO thinks is the button on the floor, next to the gear selector. It looks like it has a 4F 1R transmission, no high/lo, or secondary gear selector.
The only control is see looks to be the engine throttle on the right of the steering, then the clutch on the left side, and on the right side 2 brake pedals, and a engine speed boost pedal (sorry, I don't know the official name). Then there is toggle switch (key switch is still in place, but not connected), the red light to the left of the engine (which I think is telling me that there is no electrical power being produced because it was never started), and a tachometer.
There are some holes in the dash, so I do assume something is missing.
I was trying to find a picture of this to compare for myself, but I haven't come across one yet.
If anyone can help me figure this out, it will be much appreciated.
Thank you
Thank you
