Ford 6610 oil fitting
Carefully measure the OD of the steel cooler line. I wanna say it's 3/8 but don't quote me on that. Whatever it is, we'll call it x.
Go to any NAPA or similar auto parts store and tell them you want a brass fitting 1/4 pipe male by x inverted flare. They should be able to
take it from there. If you can take the pipe into the store with you, that would be even better.
(quoted from post at 03:03:42 08/17/21) Carefully measure the OD of the steel cooler line. I wanna say it's 3/8 but don't quote me on that. Whatever it is, we'll call it x.
Thank you, I just wasnt sure that it was a check valve. The left side is.
The LH side is a pressure-sensitive restrictor fitting designed to reduce flow to the cooler at idle so as to keep oil pressure up at idle. It's more needed on the 7610s.
