TW-10 oil pressure switch , thread sealant ?
Hey Guys,
The oil pressure switch on the left hand side of our TW-10's 401 engine is leaking.
I've got another one but I am in doubt on what kind of sealant should be used on it.
any advice ? Would Loctite 577 work ? picture below.
Are you sure it's leaking past the threads and not the body of the switch itself? The threads will seal up just fine with 1 or 2 turns of teflon tape.
Hi Bern,
You are right, it's leaking past the body and that's why I bought a new one.
I just wasn't sure what kind of sealant I should use.
Thanks for your reply :)
Kind regards,
Roel from Belgium.
