Typo in Subject heading: should read "Need help with Ford 2000 [b:f26a7c5a10]3cyl[/b:f26a7c5a10] gas with Holley Carb"
I just rebuilt this Holley carb, including the throttle shaft and accel. plunger. I followed Rachel's instructions from J&D productions on you tube: sanded the new plunger down til it just fit in the cylinder, etc., but I left it pretty snug.
The butterfly works freely by hand. Engine starts up and runs pretty good at idle...
THE PROBLEM is: pulling the throttle gradually as you normally would to rev it up has no effect. Pulling it half way , or even two thirds has no effect: still idles. The throttle will only open if I pull it ALL THE WAY down, then it opens wide and I have to try to regulate it by pushing half way back to idle. Very tricky!
I have checked and oiled all the throttle/gov. linkage. The springs are connected on the horizontal throttle rod and the verticle gov. lever. I suspected the governor (though it was ok before I rebuilt the carb) but the Gov. seems to respond by pushing the lever back when the carb to gov. link rod is removed, when running.
I don't want to tear into the governor, especially if the problem is with my carb rebuild, of course. There is precious little info about these governors on the web!
QUESTON: Is it possible the accel. plunger in the carb could cause this behavior if it was sticking? Or can anyone suggest something else?
THANKS IN ADVANCE for helping me out!
Robert B.
Snellville, GA
This post was edited by ROBOB1 on 08/15/2021 at 04:02 pm.
Robert B.
Snellville, GA
