My temp gauge seems to run on the high side. After operating it sits on the hot line doesn't really go past but definitely on the hot side. I recently installed a new radiator, 4 blade fan, thermostat and housing, water pump, and all new hoses. I mowed with the tractor for a couple hours and I really don't think it's getting hot. No boil over, runs strong. Nothing out of the ordinary. Anyways my question is, can I just install a manual gauge? Also the tractor ran at the same temp according to the gauge before I replaced everything, only reason I changed everything out is because the radiator had a hole in it. So I just decided to replace all the cooling
