I have a 1963 Ford 2000 tractor, 4cyl gas, 6 volt negative ground. It was intermittenly failing to charge the battery (red light sometimes came on and stayed).
Tapping on the regulator would make it work again for a few minutes, so I tried a replacement regulator... But the replacement doesn't charge at all. Tried polarizing the generator, still no charge.
I did some bench tests on the regulators, using a power supply across "arm" and "gnd", and an ohmmeter between "arm" and "fld"...
On the old regulator, the regulating contact opens at 8.03v, closes at 7.99v (that's a bit high, isn't it?). The cutout closes at 6v, opens at 5.5v (which i'm thinking is probably reasonable).
On the replacement regulator, the regulating contact opens at 5v, and closes at 3.3v (which I don't see how that's supposed to regulate a 6 volt battery). The cutout closes at 5.4v, opens at 1.8
Can someone verify whether a 6volt type "B" regulator should act like that at all? As differently as the two units act, it looks like I may have gotten the wrong regulator, or a defective one.
Generator passes its "motoring" test.
If I have to reorder, I want to be sure I'm not getting the wrong one again. Are there more tests I should do on the tractor first? (did some tracing on the wiring with an ohmmeter, but couldn't find a diagram online for this particular model)
Thanks in advance for any help..
