Ford 6610 oil pump drive
mikewood869
Does anyone know if you could put the oil pump drive in a 6610 with the block on the tractor? At the moment the engine balancer isnt on too, but that will be put on later today.
Drop the drive gear down thru the hole here the tach drive goes, then install the pump with its drive extension making sure the extension splines up with the drives splines
Make sure you time the balancer to the crank gear
