Hello all,
Just picked up a new to me Ford 6610 Series II. Overall really nice tractor. A couple questions for people who know a lot more than I do.
Are these engines just naturally loud when idling? It sounds good from what I can tell, but the overall noise is pretty loud coming from this engine. I've read these 268's just naturally make a ton of racket. Wanted to makes sure my timing is correct and not out of whack. It does have a DPS rotary pump on it as well, which I guess could make it louder.
My 2nd question is the classic starter problem. Every 3-4 times I go to start the tractor the starter just "spins". I checked the battery and it's right where it should be. Checked the alternator to make sure it's charging. Is this most likely the solenoid on top of the starter or the relay switch mounted to the side? Sorry if my terminology is off. Photo below.
I think I might start by cleaning all the terminals. Is there a test I can run to make sure the switch/relay is working? The starter was rebuilt last year so it could be that it just wasn't rebuilt correctly.
