Neighbor offered use of his 3000, provided I get it running:
Fuel system, cleaned tank valve, it leaks, but installed new in line filter
Carb, Zenith, was redone years ago, don't plan on opening up yet
Distributor vacuum connector broken, stripped threads, do I really need or can I plug?
Starter solenoid appears to switch on fine
Starter, Wilson, needs rebuild or replace, gear doesn't move and has bad wear on gear end
Flywheel turns
Havent got it to turn over yet, next trip, but any insights appreciated
Flywheel turns
