I just bought a 72 Ford 2000 that I'm going to use to brush hog with. Unlike the 1710 that I have that has adjustable stabilizer chains on the outside of the lower lift arms, this one only has light duty chain on the inside of the arms attaching to light duty C shaped brackets next to the pto shaft. It does have the brackets under the fenders to attach the stabilizer arms on both side. Do I need to run one on each side, or is a single side arm enough? I temporarily have an adjustable chain on both sides, but when fully elevated the chain starts to bind because the front pivot point is not on the same axis as the lower lift arm. Thanks in advance for your input. MBF
This post was edited by mbf on 08/08/2021 at 07:59 am.
