841 electronic ignition
grandpa Love
The 841 we got this week has an
occasional miss. It also has electronic
ignition. Pulled spark plugs, cleaned
them,and checked gap. No difference. Any
thoughts? I know nothing about EI. I
hate to throw parts at it. Maybe plug
wires? Timing? Coil? Put points back
in??!?! Lol
Could be as simple as a bad plug wire or bad plug. I use NGK3112 plugs in my Fords. Also could be a valve that needs to be adjusted. A compression check would find a valve problem. I'd make sure you have a good blue/white spark at each plug that jumps a 1/4 inch gap.
You want at least 100PSI and something like 125-150 is even better. Below 100PSI shows a wore engine
(quoted from post at 20:01:30 08/07/21) The 841 we got this week has an
in??!?! Lol
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto96743.jpg>
ow, you know that you have been messing with engines long enough to know that a miss on one cylinder eliminates those things that are common to all! Common to all is easy, coil, carb, EI, timing & maybe others I can't think of at the moment. But, specific to only one cylinder would be valves, compression, spark plug & one wire, and reaching a little, even a portion of the distributor cap.
