ford 4630 blowing 5 amp fuse
Peg
New User
I have a 4630 Ford that is blowing 5 amp fuse that is the relay fuse.We replaced the relay but when you turn key to start tractor it blows the 5 amp fuse.Any help is appreciated
This post was edited by Peg on 08/06/2021 at 04:10 pm.
Probably a ground somewhere in the
control circuit. I'd check the wiring
from the left side shields below the fuel
tank through the pto safety switch and
neutral start switch. Somewhere in that
circuit there is likely a bare wire.
Could also be a bad relay so if you had a
spare you could swap one and see what
happens... But most likely a bare wire.
Rod
