Ford 7710 loader
redbull
I have a Ford 7710 fwd, cab, any of you guys know whether a 7411 loader off of a 7740 tractor will fit without a lot of trouble, thanks
Cant give a definite answer. Had a 7700 and have a 7840. They are different series of tractors. The powerstars are different to the preceding 1000 and 10 series. Both are 4 cylinder engines but suspect castings like front bolster may be different. All I can suggest is a tape measure and check everything, the cab will be a challenge as well.
The loader itself should fit... The issue is that a 7710 likely had a different Mount kit. The front bolster would be the main concern with bolt hole positioning but the basic geometry would be pretty close. I'd say if you're handy with a torch, welder and drill you could make it fit.
The transmission mounts and rear geometry should be the same however the lower fuel tank on the 10 may get in the way. You'd need to measure very carefully or be prepared to move stuff.
Rod
