TheSkycrane
New User
I have a old Ford tractor and I am new to the old Ford tractor community. I have a 172 cu in diesel and it was missing the injection pump, lines, filter housing, throttle linkage, exhaust and intake housing. I checked the engine out and it seemed ok. I got a manual and found a pump and lines, bought a new spin on water separator filter and housing (10 micron). I have performed the timing procedure and will attach pictures. My timing gear wasnt horizontal like the picture so I took the hex gear out for inspection and to see what the best position was without it so I could see the gears mesh. I reinstalled the hex and the gear in the observed best position with number one at TDC and 18 degrees lined up. The big radius is indexed like the manual says and I think I found the timing mark moved it 1/8th to the right of the stationary line and placed the pump in. Sound correct so far?
