Model 600 oil pan
Steemaww
New User
So here's a question. I recently discovered a big concrete boulder in a field with the oil pan on my Model 600 and did some major damage to it. I'm looking into replacement parts but as I did not see the pan available here, I don't know where else to look. Any advice on where to locate parts and any links to videos showing how to do the actual work would be greatly appreciated. Everything I have found so far is for 8Ns. Thanks!
Many of us here buy the less frequently needed parts from a dealer on line. Messick's in Elizabethtown PA is one that is very popular because they carry more stock than most. The oil pan is available and is 367.00. you should also order a new gasket. You may be able to find one at a salvage yard for half as much. If you were to share where you are you will find out where there are salvage yards near you. The job is straightforward. Do not use RTV silicone for sealer. Get some Permatex gasket sealer and apply it sparingly to the side that will be in contact with the pan. be careful to not ovetighten the screws because the gasket could be distorted.
I did find one at a salvage yard for 85, but no drain plug, and that was destroyed in my accident as well. Thank you for your help!
Sorry for the delay. Trouble with my photos. If you still need one have this one at a reasonable cost. My email is open
<a href=https://imgur.com/AQZ2lIC>
AQZ2lICl.jpg title=source: imgur.com
</a>
<a href=https://imgur.com/fmWI2B3>
fmWI2B3l.jpg title=source: imgur.com
</a>
