Chris Hetrick
Haven't been on here to pester anyone lately, but I have a question on a bolt on my Ford 3000. I have looked everywhere and I can't find out what it's purpose is and its leaking hydraulic fluid. When I tried to tighten it, it just spun and I then realized I could pull it out (with a loss of hydraulic fluid) but it just spins in hole and won't tighten. What do I do??? It's been so long since I've posted on here, I'm having trouble figuring out how to post a picture! OK don't know if this copied pic or not, but the bolt is located just below the plug used to check hydraulic fluid level in rear diff. It requires a screwdriver to turn, whereas the plug above it you use a wrench on. I hope the picture posts!
tractor
tractor
