Was using the tractor the other day, turned off the engine and now the starter will not spin. It will very easily start if I pull it off with another tractor or vehicle but not by turning the key on to engage the starter.
This is what I have done so far:
Checked the neutral start switch 4-5 times -have continuity with lever in neutral position but not in High or Low Range.
Have continuity and voltage running through switch when put in start position.
Removed the starter and took it to a repair shop for testing--
everything tested Ok.
Replaced starter and re-attached all wires. Have continuity and voltage from the positive battery post to all the wires on the starter and solenoid with the key off or on. But when the key is put in the start position I lose all voltage to the starter and solenoid.
There is a part underneath the ignition switch about 2-2.5 inches in diameter that has a cable from the positive post of the battery to a terminal on this part and another cable that runs from a second terminal to the starter solenoid. There is a pin that sticks through the sheet metal underneath the key that will turn left and right slightly. Assume it is some sort of a relay but don't know why the pin on it has 2 positions. At any rate I have continuity through this part whether the key is in the off or run position. Sorry but I can't remember about in the start position can check that again tomorrow.
Sorry about this being so long but I hoped if I put everything I did in the first post it would help to rule out some issues that could be causing the issue.
Thanks in advance for any help!!
