Jubilee hydraulic problem
I took the manifold off the hydraulic pump and replaced the two orings. Now the three point will not work. The only thing I can think of, is maybe I have a air lock. Does anybody have any other suggestons.? If it is an air lock. How do I fix it. ? thanks in advance.
Maybe the pump didn't prime. To check
loosen or remove hex plug from the pump
and run the starter without starting. Oil
should dribble out of plug hole if primed.
If no prime try running the tractor with
plug loosened and see it oil starts coming
out. If nothing you may not have gotten a
good seal on the suction side when you
replaced the seals. Also you might try
pressurizing the hydraulic reservoir with
some air and see if the pump will prime.
