classiccarswest
New User
1975 532 with a 3 cylinder diesel. There is a bucket and a box blade on the tractor.
is it possible to remove the pan without splitting the tractor? meaning without undoing the front axle assembly and bucket?
i've read its possible to loosen the front bolts, cut them and then replace with a longer bolt?
not sure which ones to replace? the lower ones in the pan or the upper ones into the block?
is it possible to cut the ones in the pan that go into the front axle support assembly and replace those?
any ideas ?
any ideas ?
