Ford 3000 Axle swapped to 3400
Hartkem
New User
Another members posts on here inspired me to swap out my light duty agricultural front end for a non adjustable commercial one from A 3400. Ive completed the swap and started reinstalling the radiator and realized I no longer have bolt holes for the radiator or the nose cone. I think I am missing brackets specific to the industrial model or my lower radiator baffle off the 3000 needs to be swapped for a 3400/335 model.
This post was edited by Hartkem on 07/19/2021 at 07:05 pm.
I have a 3400 bolster that has tabs cast in it for radiator and nose tin bolts to it too, Worked on one while back that tin part was rad support and nose tin bolted to it too. Depending on year what setup it
has.
(quoted from post at 15:51:22 07/20/21) I have a 3400 bolster that has tabs cast in it for radiator and nose tin bolts to it too, Worked on one while back that tin part was rad support and nose tin bolted to it too. Depending on year what setup it
has.
Thanks I was able to find a metal tray that has the rad support and nose cone bolt holes.
