Josh M.
- Location
- Northeast Ohio
For some reason Im unable to respond on my post from earlier, but I
pulled the pump off my tractor earlier today. I ran air through the little
metal pto line to test for leaks and found that when the pto was on,
air would leak from around number 15 where it meets with number 1.
When the pto is shut off the break band would tighten and air would
leak around number 29 on the pto valve. I pulled it out and found
super deep gouges on the brass bushing part of number 15 and
where the cast iron sealing rings are on 1. Looks like it ran without
oil, probably when the old pump went out, I know I shouldve checked
that the first time but I was racing against time before I had to head
back to school. Im getting parts ordered and a new seal for the pto
valve. 1 needs completely replaced and the only replacement I
found comes with an entirely refurbished clutch pack. My question is
that when the pto is off, should air have been able to leak around
number 29 on the pto valve? Im not sure if it leaking will prevent the
break band from being tightened enough or not.
