Jubilee hydraulic FIXED!
Al in Il.
Finally got the hydraulics working properly after quite a few possible solutions - it was the back pressure valve. Mine was frozen/stuck solid!
I found a good used one online very cheap. The timing couldn't have worked out better.
Hi Al, glad you got it fixed. I thought you had found the problem when you found the frozen back pressure valve. I followed your posts with interest as I have a NAA too. But couldn't offer anything since I've never been into mine.
(quoted from post at 17:11:04 07/15/21) Finally got the hydraulics working properly after quite a few possible solutions - it was the back pressure valve. Mine was frozen/stuck solid!
our perseverance is admired! Good for you.
