8210 FORD PTO PROBLEM
ERNIEMENARD
New User
ANYONE KNOW WHAT WOULD CAUSE THE PTO TO STOP WORKING AFTER IT HEATS UP? ABOUT AN HOUR OF MOWING AND IT STOPS WORKING,,STILL HAS ENOUGH TORQ THAT YOU HAVE TO SHUT TRACTOR DOWN TO UN HOOK SHAFT.
If it consistently works good cold but not hot, that usually indicates a good sized internal leak in the low pressure hydraulic system. If
so, some pressure testing is in order here.
