Billy Breeden
New User
Ford 7710 II last year had water in the engine oil, My Experienced Mechanic tore the engine completely apart and he was impressed as it showed absolutely no sign of wear at all. He checked for blown head gaskets, cracks in the engine block but could not find anything wrong with it. So he poured some block seal and head gasket repair (K&W) into the radiator just trying anything that might solve the problem. That appeared to have solved the problem as I used it last fall to carry hay out of the field. Well the other day I was bushogging in some very thick briars and the air filter light came on the dash. after using it a few more times I am seeing water back on the dip stick.
