Ford 1910 Front Axle Dipstick
jimfowler30
New User
I have lost the dipstick on the front axle of my Ford 1910. Replacement part number is SBA398400150. The problem is both this part number and the replacement are both threaded. My axel is not. It is a clean hole. Local dealer is at a loss. Any ideas?
Thanks!
The axle housing has the same part number for the 1710 and 1910. However the 1710 shows a different part number for the dipstick 83/8-83 (SBA398400260) and after that it uses the same dipstick as the 1910. The SBA398400260 was also used on the 83/8-83 1310 and 1510 and described as dipstick, rubber. The SBA398400150 is described as dipstick, metal. SBA398400260 does not appear to be available any more.
Mark
(quoted from post at 23:32:59 07/13/21) The axle housing has the same part number for the 1710 and 1910. However the 1710 shows a different part number for the dipstick 83/8-83 (SBA398400260) and after that it uses the same dipstick as the 1910. The SBA398400260 was also used on the 83/8-83 1310 and 1510 and described as dipstick, rubber. The SBA398400150 is described as dipstick, metal. SBA398400260 does not appear to be available any more.
Mark
Thanks Mark that's very helpful! Any suggestions for a substitute for the Ford 134 Fluid?
